Another panel for the same house. This one on the lower level. Wall size is 174.5" x 106" tall
I made a few parts and brought them to the house. The stone around the gas fireplace was level but the sides tilted 1/8" to the right forming a slight parallelogram. I used a laser to put the stile plum and did the scribe and cut it with the track saw. Same with the second side. Then I plumbed the two sides and scribed them to the wall. Took measurements between the shoulders of center and wall stiles. Put a level line on all 4 parts for a reference. The floor from the left corner to the left side of the stone is pretty level, and then rises about 5/16" to the right corner. The ceiling follows it for the most part.
I enhanced the laser line
Brought everything back to the shop and made the parts and put things together. The right and left sides will be complete and the center will have open sides to mate with the rest in the field. Gotta get it into the house ya know.
Built the 3 frames to make sure things lined up and I needed to cut the tapers on the bottom and top using the verticals from the house as guide points. Plus to put tick marks on the rear of the panels to have alignment marks for installation.
Put the center together with the right side so I can close it up using pocket screws and then sanded the joints flush. I'll do the same for the left side and then it gets primed.
