1 - 14 of 14 Posts
Box Builder
I did a search but didnt come up with much. Are there any decent portable heaters out there for heating a house while the boiler is still unhooked. Most of what I've found are like 5k watts 240 volt that run around $75-$110. Are these things worth it.
diplomat
The electric haters are cheap and no fumes, no hauling fuel, but they don't put out much heat. 3.4 btus per watt, you can figure out what you need. I have a couple, one has a dryer plug on it, the other I wire direct to a breaker usually.
I have done it once or twice . Works well enough to heat the space up . Just that you use a lot of breakers in home . Other wise you trip breakers using power tools on someone . The stand up moving ones work best . Did like two per room .
These heaters are bada$$. We have heated 3000 sq ft houses in the dead of winter with one and a couple fans. And usually we aren't buying the electricity but we have to buy diesel/propane.:thumbup:
Remodel
Yeah. I don't need anything that hard core. There is a wood stove in the house too. Just need a few small heaters, but better than the 120 volt 1500 watt ones.
You can get good $1500W heaters for $30. You can get a 5000W heater for $300 or a 20KW for $1K. The 1500W ones are much cheaper per watt than other options. If you don't want to keep the heaters, pick up some of the garage type heaters, and it's pretty easy to resell them. Or just use them in your garage:whistling
1 - 14 of 14 Posts
