I have a client who wants converging pocket doors between two parallel 2x4 walls . Walls are to be sound proofed so that is the reason for the two walls . If I space the walls 3 1/2 inches and put the door track between on its own framing I assume I can make it work without using the split jambs . The other quirk is that this is on a concrete floor with in floor heat and they want no tapcons in the floor so everything is to be set with adhesive . I was going to put the pocket doors in one of the walls as usual but they want both jambs to be equal so between the walls it goes.Has anyone done something like this before or do you see any flaws in my plan to meet their wishes . Thanks
