Are there standard code requirements for taking a plumbing vent out a house wall rather than up through the roof? 1 1/2" PVC.
Thanks!
Your neighbor does not want to smell your sewer.
That was spectacularly unhelpful Killer! :smartass:
I was looking for something more like: "[The] vent has to terminate at least 6" above the roof line. You can run your vent surface mounted, on the outside wall and terminate it above the eave."
code is different in every State
here in WI it became code legal a few years ago...ive never done it....you wouldn't want it at ground level...you'd want it up high...and if your going up high why not go out the roof.....its supposed to be an option to avoid a AAV.....ive never had a bad AAV when tested and ive never had to replace a AAV......im sure in 20 years i will at some point(they will all wear out)....venting out the side is only to avoid a AAV...just use a AAV and be done with it
