1 - 20 of 21 Posts
We have leased both in the past for jobs with concrete or underground utilities. We are considering buying a new one but only want to buy one not both. If you had to have just one which one would it be?
Well we have a jumping jack, its great like was said before on anything but sand. it will do sand but very carefully, we dont have sand too often here so we dont worry about it. Backfilling basements, waterlines, and concrete pad prep work its great!:thumbsup:
Al Smith
i personally prefer a plate than a jumping jack up here is mostly clay.. but Ive done alot more crete prep..
Discussion Starter · #10 ·
I got a rented plate compactor and like it for its ease of use. The only thing i noticed was in sand if you come across any clay it sticks to the bottom and then coats itself with sand. This slows the machine down and leaves groves. Its easy to fix scraping it off every now and then though. Alot easier than a jumping jack.
Al Smith
I had that problem with a sandy driveway cut i compacted. Boy it sure does slow down the forward movement. I would make two or four sixty foot passes and then tilt it forward and scrape the bottom with a flat shovel. When I resumed the thing would practically run away from me.
jumping jack or vibe plate? what you select depends on what you're doing and the type of soil you're compacting...on a walk behind, a cohesive soil, you want the impact to drive the soil particles together, most efficient...on a granular, you want a vibe plate, it shakes the stones, sand together..although you can use a vibe plate on cohesive soil, without the proper moisture content, and watch your lift limits, a jumper will be more efficient.
Instead of buying new, buy used and then you can own both. I have both...matter of fact, 2 plates, 1 with a water tank, because they are handy, and one without. I bought my last one for $20 at a garage sale. $85 in parts later for the Honda, I have very little in a decent plate.
Jumping jacks around here sell for $200 and up used.
Gumby
You can compact 9" to a foot with an elephants foot or jumping jack.
A regular small plate compactor will barely do 2-3 inch lifts adequately.
If you dig a small trench you need the elephants foot.
The plate tamper makes great work of large areas, but don't delude yourself on how well compacted the material is. That being said there are some very large plate compactors that some guys use. But its rare.
Joasis is right about used. You can also look at rental yards for used equipment especially at the end of their fiscal year(sept oct). I got an $1800 tamper for 400. Get the Honda engine always.
Stud
Most laborers prefer plates. Easier to lean on than jumping jack.:thumbsup:
It's nice to have both types. Always seems like you need the one you don't own. We have 5:
1. Small vibe for blacktop
2. Medium vibe plate we rarely use any more
3. Big Bomag vibe plate
4. Jumping jack
5. Plate on excavator (My personal favorite)
Stud
We used to rent quite a bit before finding Bomag at the "right" price. Ours weighs 700 lbs. The only problem with ours is that the belt guard isn't that great so we've gone thru a few belts. We're going to fix that problem this winter.
I would look at Wacker before Bomag if I did it again. Easier to get parts. Also heard good things about Weber's.
Wacker makes a good machine. We have a small reversible plate that i prefer over most of our smaller plates. We also have a 1500lb wacker diesel plate packer. Great when its running. Its been ridden hard, and put away wet. It has outlived our expected life span for it by double. The shop is looking at going through it this winter, and im hoping it comes out like new.
1 - 20 of 21 Posts
