1 - 20 of 22 Posts
Okay so I had a teeny job where a cust wanted a plug installed for a micro I asked them where to put it in the cabinet or outside it. They chose outside I di it got paid and left. Now they're mad saying I should have put it inside and I hae to come back take it out fix drywall and install new (with fishing of course) inside. I offered a reduced price to do that but its "my fault" for not insisting it goes inside. They chose where I'm not gonna argue where to put it. You tell me I do it and its done.
They want to escalate, keep calling every few days and I'm sick of it. I don't want to go to ct over it. What do you guys think? :censored:
Of course. Paid cash too! Problem is didn't use the 6 page iron clad contract because it was a buck and a half job and didn't think anything about it. Just the quickie 1 page paper. I can't be held liable for their decision as to hwere to put it. I know I can 't but people are sue crazt
Ya see, this is whats wrong with most "handymen". Says he charged $150.00 then takes shortcuts. Should of told them the plug had to install inside the wall. At that price its very doubtful he pulled a dedicated circuit. If he did he misquoted the job by at least $200.00. Either way its an unhappy customer who trusted him to do it right.
I don't think the issue was if it was in the wall or not, the original post said either inside the cabinet or outside.
Mounted microwave under a cabinet plug goes inside, free standing counter model plug outside.
I hope you ran a Home-run for it.
Greg..... Just a point of curiosity....
GE makes one model (used it but don't remember the model number) that can countertop, or hang under a cabinet (not as a built in per se)
Figure that can run off the SABC or dedicated?
I don't know?????
Just read this post 3rd time where did you get this info?
123..... I don't know of many jurisdictions that would not technically require a permit for that install (cabinet or wall).... let alone a dedicated circut.
I guess that could play two ways for you, as I don't know if you as a handyman or the HO could be culpable. The HO would be ultimately responsible I believe.... I would doubt they are going to court, if that's what you ment by "ct"
If you ment contractor talk, you won't have any problem:thumbup:
Are these people wacko... or is there another side to this story.?
Is it built in. Did you run a dedicated circut.....probably not for $150.
Whats the wattage/amperage on the micro.
General Contractor
I don't know?????
I don't know, but when ever I remodel a kitchen or when I build a new house, my electrician always does a dedicated circuit for a microwave. Some of this microwaves draw 1500-1800 W and the way he explained to me that he makes sure, the load on each breaker dose not exceeds 80% of its capacity.
I'm sure if Sparky or RSelectric checks this post, these guys are pros at this stuff maybe they can answer that or a few other guys who know this stuff.
It would behoove anyone claiming that they are a pro to check the spec sheet of the proposed appliance(s).
If the HO knew how this worked, there would be no reason to call in a pro.
Over the counter (installed) micro-hoods typically need a receptacle in the cabinet above. Built in's with a trim kit can typically be installed behind the actual unit. Countertop units typically plug in to the countertop receptacles.
I always suggest a dedicated circuit for a microwave. Simply tapping on to the SABC for an installed microwave sure get's me a lot of service call work.
Researching spec sheets sucks, but it beats going back and making amends for mistakes I would imagine.
I think this guy has the right idea. You might want to make nice with this HO it doesn't sound very expensive to fix. But what I will say I will be very costly when she turns you into the building department and they turn you into the licensing board.
Hair Splitter
Sounds like the OP was in over his head. Adv123, why should you tell them where it goes? BECAUSE YOU ARE THE FRIGGIN' PRO, SUPPOSEDLY.
I would never install something in the wrong place per the customer. I would walk. Heck, I have walked from bathroom jobs because they wanted some crazy butt ugly tile work that I refused to put my name on.
As for the dedicated circuit, I am all for frig and micro on one of their own, period! I know that frig's don't pull as much, but if a breaker goes, I don't want the frig on it.
1 - 20 of 22 Posts
