The pintle will have a little play in it, but I've pulled out 7500 lb skid steer with my baby 1500 a few times. We gave a pintle on the equipment trailer. It's got some play in it, that's for sure. It gets a little sketchy at about 50 mph
That isn't the topicdo you have adequate licensing to tow trailer with a class 6?
THAT'S RIGHT, A-W! You got my back, I got got yours.That isn't the topic
That's very true.cdkyle said:I don't personally have any pintle hitches, but I see a lot of them being used. It looks to me that one of the advantages is; it appears easier to hook up to trailer by ones self. Just line the truck and trailer up, back into it, as opposed to being dead center over a ball.
If you use an actual pintle hitch and not a ball/pintle combo hitch there is hardly any movement at all. Personally I can't stand using the ball combo hitch for that very reason.Why not keep it all the same if you have multiple trailers that are gooseneck? Might be more simple and I assume you have multiple trucks to pull it.
We've got just about the same trailer for our skid steer or small equipment but not a dump has a smaller beaver tail. It has a pintle hitch and I've pulled our t300 at about 10k with my 11 f-250 with no problems. The only thing I don't like about the pintles is how much they move around in tow. I also think when you get into the higher weights the ball hitches won't cover the weight.
I use a real one and it's got play in itpeteo said:If you use an actual pintle hitch and not a ball/pintle combo hitch there is hardly any movement at all. Personally I can't stand using the ball combo hitch for that very reason.
They are the same size, it's just the nature of pintles. It has a lot more to do with weight distribution than pintle itself. Bigger trucks weigh enough you don't feel it, like a pickup.ESSaustin said:From what I gather, you need to size your lunette ring to your pintle. If not, you may have an undersized ring, which will bang around. A proper mated ring to it's respective pintle should not have slop. Again, I have ZERO experience with pintles, all this info is what I have read.... I switched from ball bumper pulls to goosenecks maybe 7-8 years ago, and pulling GNs is way better. The reason I am thinking of going pintle is because my new International rolloff has one, and was thinking it could (easily) pull the skidsteer, although the Dodge chassis cab would be the primary tractor.
Fifth wheels are the worst. Definitely go goose neck over thatdayexco said:pintle might be "okay"...easier to hook up...but once hooked up, i'd MUCH rather pull a fifth wheel than a tail dragger.
Even easier with a backup camera. Thing is great, I usually hook up by myself and it saves ten trips back and forth to get it just right. Thing is awesome!I don't personally have any pintle hitches, but I see a lot of them being used. It looks to me that one of the advantages is; it appears easier to hook up to trailer by ones self. Just line the truck and trailer up, back into it, as opposed to being dead center over a ball.
fifth wheel/gooseneck...it's local jargon apparently, i think you and i mean the same thing. 2 5/16" ball sticking up thru the bed of your truck approx. 4" ahead of the rear axle.Fifth wheels are the worst. Definitely go goose neck over that
