1 - 20 of 20 Posts
Mike I built the splay,hooked up the hood to the pipes,and sheet rocked it. The finish work is in the finish guys contract so I didn't do the molding. But I could of. I am going to get some more pic of some different work I did and set up a web base resume. Which will turn into my business site when I am get every thing ready and legal.
Kurf- what the boss wants is what the boss gets. ;)
Mike Finley said:
How did you frame the compound curves?
Well first I framed the top box. Which was a rectangle then attached that to the wall and ceiling. Framed a 2x8 box around the hood. Then used 1/4 inch fiberboard marked points from the outside of the 2x8 and one to the outside corner of top box.
Made two patterns then temped them up on the two side to the wall. Evened then marked the curves. Used two layers of 3/4" plywood cut to the curves then attached on the wall.
Next attached the fiberboard sides on. Then took the front side piece wild and temp it up and marked curves. Cut fiber board. To get the tutor hip rigid I use 2x6's put in place marked cut to curve and replacated for other hip. attached to each corner of 2x8 and top box. Then attached fiberboard. Next came 1/4" sheet rock. Wetted it up a little and fit curves perfectly. Tape and mud.
And the finish guy and painter did the rest. Oh yeah the electrician hooked up the power. :Thumbs:
Discussion Starter · #17 ·
Thank for your nice comments. I merely framed that piece when I worked for a developer as a utility carp/ asst. sup. All the other work in the pic was done by some top notch subs. Though considering that only 1/4" rock was used my work had to be tits on. ;)
1 - 20 of 20 Posts
