1 - 20 of 26 Posts
Design Build
So after the new fence turned out nice, I adjusted my gaze to the back deck.
I had "pre-stupid" prices lingering in my head..................wow. $7 PSF for TimberTech is now $14 PSF
I will be waiting for a drop in prices for this one.
Before:
Old deck.....slippery when wet and in need of yearly maintenance.
The previous owner face screwed through the cedar with small trim screws that the cedar has turned a corroded black.
At least his framing is 12" o.c.
514317
The Plan:
514318
I'm going to make the entire deck one-level surface so that bench seating can be placed around the future hot tub.
I broke the old hot tub/spa when I thought the pressure washer would be the right tool to use to clean it.
Nope. That's not the correct tool.
To resurface the deck will be between $8500-$10,000.
That's with me doing 100% of the labor for free.
Then a new spa or hot tub is another $7500 and the waiting list for those is about six months.
I'm looking into what are my options for hidden fasteners. I thought I would like the Camo system (edge screws) but I saw it installed and for some reason I am drawn to looking at the screws. They are not hidden..............just not through the face.
I will return to this thread once I can pull the trigger on this project and get it rolling.
We've given up on any carpentry projects on our place.
I must do the roof, but I'm trying to work a deal on that.
Other than that paint and some drywall work is it.
I do have a scad of left over materials, so we can do some small stuff, but no big items.
The greenhouse is on hold till next year at least.
Stelzer Painting Inc.
I've only used Tiger Claw and the Camo "hidden" fasteners and I know what you mean by Camo not being truly hidden, but they ARE extremely easy and fast to install and don't require the addition of a clip. I've been happy with Tiger Claw though for harder woods. I guess it depends upon just how hidden you want the fastener to be. I think there's a few that require securing from underneath, which wouldn't be ideal for you, given the distance from the ground. That's about all I know on the subject though.
GC/carpenter
The edge clips suck as far as looks. I really like the camo drive system. Fast and installs with a consistent groove.
They are priced decent as well.
Mike.
___
Design Build
On the deck I saw it was a light gray colored plank and the screw holes were dark so they stood out. I might get lucky if I matched the screws to a medium or darker plank. I trust deck builders so I appreciate your input. One of my favorite builders up here always uses the camo drive system.
I don’t think this will be something I get to until September or October unless price has dropped substantially.
Never understood why fasteners have to be hidden.
Face screw the damn thing.
Just make sure to clock all the screws in the same orientation.
I reccomend square drives.
Sent from my SM-N960U using Tapatalk
Always Learning
I tried Garapa decking for my personal deck a few weeks ago. It was grooved and then I used the IPE Clips from DeckWise. The most challenging part was dealing with curvy hardwood. Real pain but happy with the results. I also would augment with countersunk screws and then glued in plugs I cut with the Snappy plug cutter. That bit was awesome! I wouldn't recommend this to my clients unless they really wanted real wood (like my wifey...).
Way to slow. With the Camo clips I can set 8-10 boards, clamp them tight and have them screwed off in less then 2 minutes. And the gap is consistant with no effort from me.
GC/carpenter
I think the gun attachment is under 200 bucks.
It's nice to be able to use a cordless drill on it.
Mike.
___
Only thing I don't like is the collated adapter. It is a bit janky. Too easy to run out of the groove and scratch the deck.
Always Learning
Can I sidetrack this topic for an opinion oh wise CT members...I have this handrail detail to build. Plan is for the post to have a flange welded on the sides. I will then cut/route a groove in the end of the Garapa decking boards. I will slide them over the flange and then drill and bolt the boards with exposed stainless fasteners.
My question is the middle. Garapa is a dense hardwood and the boards are not perfectly flat or straight. I want to keep this look...so I am thinking of drilling the center of each rail and then using stainless all thread and spacers & bolting everything together to keep them all in alignment... anybody have a better idea?
Deck Builder
excellent mate!
Azek makes a leveling post mount. You could do something like that to plumb and level them.
1 - 20 of 26 Posts
