Perkins makes good engines but they will not start when its 40 degrees or colder. If you plan to use it in the cold get a block heater on it. Do some research on it and the other sizes. The same maching may be used for different models but they just had different size engines. This engine may be from a different machine. Also look for the tag on the machine. The body part with the decal may have been changed.
