1 - 15 of 15 Posts
Want to play a game?
We just finished the pavers on the patio here. Also painted the house. Now on to the pergola(s).
All rough sawn beams and posts. 6x6 posts, 6x8 beams and 4x8 rafters.
Got to use the Prazi a bit. I'll do a review on it later.
Property House Home Building Roof
Property Building House Home Real estate
Property Roof House Real estate Home
Property House Roof Home Building
Cut from the Prazi. Not smooth but being rough sawn lumber, it does not matter much. The cut is straight and square though.
Tablecloth Wood Table Linens Textile
Some progress...
She (HO) could not keep up with painting them all before we got them up so she gave up and said just build it. lol
Roof Property House Home Building
Property Building House Home Swimming pool
Property Roof Building House Patio
Asphalt Road surface Water Concrete Road
Property Roof Building House Shade
Roof Property House Building Home
Big and simple. I like it. I'm not a fan on all the detailed ends on a simple house.
For the tearout you could mark your lines with a sharp blade and cut to the side of it by 1/16". It'll still tear out but it'll be even.
I tried a couple but that Prazi is a beast. So I gave up. They all will need a little attention but not too much do to the nature of the rough sawn.
designer + carpenter
Big and simple. I like it. I'm not a fan on all the detailed ends on a simple house. For the tearout you could mark your lines with a sharp blade and cut to the side of it by 1/16". It'll still tear out but it'll be even.
Just hit it with a sanding block after the cut, before you move it. I like the rough cut on the rough sawn...looks appropriate.
Artist and not a curator
I like your blocking that looks sharp.:thumbup:
I agree with ninzan, simple "deburring" is all that's needed, makes it look finished in a rough cut sense.
Discussion Starter · #13 ·
Thanks guys. She is going to finish painting and she wants retractable screen on top. We will also be building a little pergola over the BBQ area. So I want to get pictures of all that.
I finished this up just before the winter hit the fan. Big and simple with lights and fan package. I was curious about what the different angles and layouts are called so after Googling for a while this tapered look is called Japan style. Send the finished picts.
Beam Architecture Wood Building Room
1 - 15 of 15 Posts
