Are you using a radial arm saw on site for those perfect square cuts?
You didn’t know how to use itI haven't seen a radial arm saw in twenty years.
Large, heavy, dangerous machine that didn't do anything very well.
Not if made portable & moved properly. I’ve got a lot of chit that is way harder to handle & set upWhy would you want to set one up at job site. I guess no one would steal it. To big to be moving each night.
griz, you've said some silly $#!t, but that has to be about the silliest. Following this "reasoning" you'd drive to work in a tank so you'd never have to worry about a fender bender.Like i said earlier theres not a miter saw that would hold up on a commercial or residential crew.
Back in my union days as a young carp, radials were set up on every job. As mentioned above, they ran all day. True & everlasting. Timber framer buddy of mine has parts for all of them ever made. He’s got some old chit, a lot of it 2nd & 3rd gen. passed downWay long ago I worked on a commercial job running the survey crews that set line and grade. We were building a major addition to a hardwood paper mill. For one long snowy winter we formed and poured huge foundations for equipment and buildings, with the average day seeing between 30 and 60 redi-mix truckloads of concrete. Pads to 7 feet thickness. 3" dia anchor bolts. The carpenter crew was about a hundred men, and in their large heated shop were two large cut stations, each having a 16" radial arm saw wired to 220V. All the formwork for the 'crete was plywood and 2x lumber, and it all got cut in the shop. The saws ran all day every day.
