hey guys, I was at a repeat customer's house today, good client and does several high end marvin window units each year with me. The house has CEDAR clapboard siding over 1/2 foamboard sheathing(no tyvek, no plywood)
I know he has issues with peeling paint on the siding, even though the house was sanded, primed and painted a few years ago, he has areas where the paint actually gets water behind it and you can pop it and water runs out. I don't see where that much water gets behind the siding. the roof is newer and no visible signs of leaks inside the house. The siding isn't falling off or cracked where water could be getting behind it.
My thought it that because he has ZERO house wrap, no sheathing, that the humidity of the house is escaping through the siding and getting to the paint and can't get out. That's problem number 1.
every time I do a window, we end up replacing a bunch of siding around it.
the paint just peels right down to bare cedar in spots.
no, problem number 2,
The attached 2 car garage. when you enter the garage, the left wall is an outside wall, space above the garage is unheated, but the ceiling does have insulation in it. the right side as you enter the garage is a wall that has a heated living space on the other side.
wall on the left and the ceiling have peeling paint bad! it's coming off the drywall, especially at the seams. the right wall, ZERO peeling paint.
Now I don't believe the left wall(outside) has insulation at all, but I know the ceiling does. The paint is peeling all the way back to BARE drywall, with no appearance of primer/sealer on the paper.
What do you think is causing this and what would be the best solution to fix it. I told him the best thing is to take the ceiling down and the left (outside) wall to the studs/joists. Insulate the outside wall. and install vapor barrier on both, then install new drywall again, tape, prime/ seal then paint?
anyone think of something else that can be done? the paint is so flaky and peeling on the ceiling and left wall that I don't think it can really be saved and it would probably take more prep work than just putting new drywall up.
thanks in advance!!
I wish I could talk him into removing all the siding, and foam board sheathing, sheathing with CDX , house wrap, then new hardie plank prefinished. I don't think he wants to spend that kind of $$. He had the whole place painted a few years ago and this is not a small house either.
thanks in advance!!
