1 - 9 of 9 Posts
I've just installed new pavers and used silica sand, just keeps blowing out.
one half inch joints, what is the alternative to loose sand?
Thanks
John
spadoc
What kind or pavers are using 1/2" joints for?
Interlocking concrete pavers have very tight joints (1/16 - 1/8") depending on the manufactured spacers on the side. - They require a fine sand (mason's sand).
Other types (clay and large concrete "stepping stones") are usually used with larger joints that do not give the stability, but may be OK for a patio, but not for a driveway or street.
Dick
As I said, what kind of pavers. - "Torpedo sand" is just a local term, but usually is not good for anything other than the sloppy, wide gap pavers and not the much more common interlocking concrete pavers.
I would suggest using a polymeric sand like Alliance's Gator Sand. It hardens when you wet it. This will keep weeds and ants out of the joints and keep the sand from blowing out.
I eat sawdust.
I don't like that stuff it doesn't drain like the traditional sands.
I used to do walkways with another company when I lived on the east coast and we never used polymer stuff.
Administrator
Sawdust follows Me Everywhere
For joints that size I would use crushed stone. It'll pack tight, keep things pretty stable and drain well.
1 - 9 of 9 Posts
