Uno mas....
I see what you mean. Optical illusion of sorts because the post at the top of the steps is 45º to the other posts since it's a clipped corner.Looks 100% better than before.
I am curious as to the railing between the stair post and the middle post, looks kinda funky.
No...it's a reality of a flush girdered deck where the outside rim is also the girder. No way around it that I know of because a cantilever won't work.I've got to ask Greg, what' s with the footings showing through the fascia? Is that a design element?
we can't do it that way here. We can't use solid beams for some reason. Always gets shot down.We build things differently on the west coast. If I only had 8 - 12", we would still frame with beams and joists, allowing for a cantilever. It takes more footings, with smaller beams and joists, but that should be no problem with a mini and mixer combo.
Beams would be 4x4's on 4' centers, with 2x4 or 4x4 joists.
I've not been able to figure that one out. Out here, everyone uses solid beams. Maybe it has something to do with the wood species.we can't do it that way here. We can't use solid beams for some reason. Always gets shot down.
one thing I do in this senario where there is fascia extends down past framing on a cast pier is i'll determine where on the pier is the outer framing edge and or corner if thats the case, and use a diamond blade in the circ saw set depth and a angle grinder to make a notch for the fascia to extend past. I've also done this to share footing/peirs on a level change on low/ground level decksNo...it's a reality of a flush girdered deck where the outside rim is also the girder. No way around it that I know of because a cantilever won't work.
Good idea. Never thought of it.one thing I do in this senario where there is fascia extends down past framing on a cast pier is i'll determine where on the pier is the outer framing edge and or corner if thats the case, and use a diamond blade in the circ saw set depth and a angle grinder to make a notch for the fascia to extend past. I've also done this to share footing/peirs on a level change on low/ground level decks
Definitely.I've not been able to figure that one out. Out here, everyone uses solid beams. Maybe it has something to do with the wood species.
We also do very little notching, as that promotes rot. We use a lot more hardware though.
