Patching brick before drywall.
1575 Views 5 Replies 4 Participants Last post by  dom-mas
I'm installing a shower using the Kerdi system over drywall. I'm attaching the drywall over the existing brick using furring strips.
Here's my problem. When removing the plaster from the brick, I found the brick to be in rough shape. I'd like to put a level coat of patch over the brick before the furring strips. As a tile guy I have a lot of thin set mortar laying around. Would this be a good repair or should I use something else?
1 - 6 of 6 Posts
I don't know about that, but why not shim out the furring as necessary and fasten it?
Doing the same type of job right. Back wall in an older house about 7' wide or so. We set a laser level on the floor attached the furring strips and shimmed as needed to touch the laser line giving a perfectly level and flat wall.
We had to build it out where that the tub would fit the space right. I don't have pictures right but hopefully it makes sense. If you don't have a laser level a regular level should work fine.
Thanks for the feedback.
I do plan on leveling the furring strips, but I just wanted to strengthen some cracked and crumbling brick before I put my tapcons in.
tmg862 said:
Thanks for the feedback. I do plan on leveling the furring strips, but I just wanted to strengthen some cracked and crumbling brick before I put my tapcons in.
We didn't really have that issue so I can't give much input there. I'm not sure if thinset would strengthen cracked brick much though. Is it possible to attach in different places or is the whole wall compromised?
I'll just go ahead and assume that it's inside? I wouldn't worry about it too much. Whatever you do will do permanent damage but it's not that big a deal.
1 - 6 of 6 Posts
