1 - 8 of 8 Posts
I am having a problem painting my door. Stripped it down once and painted with primer and enamel. When the temps went down to 30f the paint popped off. I am thinking of using latex because it is soft and flexes. What type if any primer should be used.
Remodel
Sounds like you had a surface issue causing poor adhesion.
I've never used Latex on an exterior metal door.
I use water base on metal doors but they were always preprimed never had to prime. I think door manufacturers call for water base. What is popping off paint or primer? What exactly did you use?
Oil specially formulated for steel, it Hass to has some Elasticity to it because the door will expand and contract with the temperatures
I will second the Procryl primer, it’s an excellent metal primer, for a residential door I would finish with exterior latex paint such as Duration.
Not sure if Precat epoxy can be used out doors, I would double check that, most epoxies can not stand direct sunlight.
As you have had issues I would strip door again, lightly sand, and wash / degrease with tsp as you may have in underlying contamination issue.
I also agree with Pro-Cryl Primer being an excellent metal primer but I prefer using KILZ Adhesion Latex Primer for steel doors since it bonds better with metal surfaces.
Stelzer Painting Inc.
It's your opinion that Kilz Adhesion bonds better to metal than Pro-Cryl. It's not fact though. Not by a long shot.
1 - 8 of 8 Posts
