Wondering if anyone out there has mixed latex paint into tile grout to change the color? I can't see why it would be a problem.
Most redo their bathroom every 15-25 years. Most of my clients are at the 20-25 year mark, so I disagree with that as well.Sorry to jump on an old thread, was wondering about this myself.
I don't think this question is bogus. Did you try it? What was the result?
It's bogus because it's rooted in ignorance. Just because they have a product base that uses the same term doesn't mean they are the same.
Acrylic and Latex are both polymer type products, correct? What is polymer? What types of polymers exist? So wouldn't mixing them into a sanded grout essentially just make the grout polymer modified. No, chemically they are not the same, and that is what matters. What in paint would negatively react with the grout?Most of the more expensive water proofing systems currently available are a mixture of grout and latex or acrylic type polymers, no? No. No waterproofer has grout in it. Grout broken down is simply cement and colorant. Why would you think that grout is in waterproofing?
As for the warranty being voided, basically sneezing while applying a product seems to void its warranty. How so? What is your experience with warranties (specifically)? I know for a fact that Ardex, Wedi, Schluter, Mapei will all stand behind their warranties and usually go about and beyond.So if it waterproofing failure you are concerned about, make sure you have that taken care of in your underlayment. If it is a cracking issue, it seems that adding a polymer to your grout would help prevent it. Polymers help in some instances, but cracking is caused by movement. Elliminating the movement is the answer, not a different product (in most cases) If it is color fading you are worried about, only time will tell. It seems that people are redoing their bathrooms more frequently than the full lifespan of a product anyhow.
