1 - 3 of 3 Posts
I'm installing some 8 1/4" Hardiplank and am planning to use a wood composite outside corner and window trim (something I've done several times in the past). Is there an advantage in using the Hardi trim products? Clean cutting is an issue, especially on window miters.
Mark
The Old Master
Mark
I put an addition (great room) 24 x 22 18 ft high. Used Hardi plank and Hardi Trim for outside corners, not window trim. Did not 45 the corners, flush nailed but ripped one piece down so the corner was the same dimension. Ripping/Cutting Hardi Plank be prepared to puirchase a few carbide tipped blades.
E-Mail me if you want a photo.
1 - 3 of 3 Posts
