1 - 4 of 4 Posts
Has anyone used an outdoor 15 Amp thermal switch to disable an outdoor pump in freezing conditions? This seems like a simple solution when pumping isn't required year round and failure only causes temporary outdoor flooding.
I'm searching for the right part, but I can not find a switch that I can set below 40º. I'd like to set it at 25º (above ground air temp) because the pump is near (but not below) the frost line.
Contractor of the Month
They have programmable and fixed temp detectors for the security industry. Or use a thermostat.
This might be what you need:
http://www.farmtek.com/farm/supplie...rollers-ft_thermostats_durostat;pgcr2095.html
I would think you need a programable thermostat that works for air conditioning. The trick is to have it turn on when hte temp reaches a set point, which in your case is a bit above freezing. The site has a lot of similar units. I've been using one of their electronic cycle timers on my aerobic system for about tree years, & it has been excellent. If you think about it, the products they sell are for one of the toughest enviroments you can find......livestock/poultry/greenhouse use.
Joe
1 - 4 of 4 Posts
