its an exposed fastener metal roof i forgot to mention that before
as much as i would like that it will never happen..... and i know the exposed fastener roofs are frowned upon on here but thats the big deal in this area... we have installed a boat load of them withhout any problems with leaking fasteners. but i agree no amount of flashing will fix this im afraidMove chimney, install new standing seam roof.
The right solutions aren't cheap.
No amount of flashing, caulk, or tape will fix that ^
Mike
I almost explained it!:whistlingIs this visible from the street? If not.....
I'd make a ridge where the existing valley is, & do valleys past each corner of chimney. That will keep the chimney step flashing on a slope so it won't dam, & divert as much water away as possible from chimney.
Joe
I think you and OP have the same plan. I concur, this is the best and only permanent fix.Railman said:I almost explained it!:whistling The ridge would run from existing valley, to the chimney corner! I'd keep the pitch the same as main roof. Joe
Yea we are on the same page that's what we are lookin at as the best solution, never hurts to ask for other opinions and ideasI almost explained it!:whistling
Joe
Pretty much the first thing i thought of as well, too much water channeling in that area to just rely on flashing solely.It's leaking all around the chimney, I'm afraid reflashing still may not be enough, the valley still dead ends right into the back corner of chimney, we are looking at adding a ridge where the valley is, creating two more valleys diverting the water to each side of the chimney, more less a cricket on steroids
