All of the sliders that I have worked on in the past, whether it be design, manufacturing or installation have an added feature. There are anti lift blocks inside the head portion of the masterframe. Typically it is a length of extrusion that snaps in place, and when the window is locked, prevents this from happening. Now if the window is unlocked, you can slide the sash to one side and lift it out, but the would be bad guy would just crawl through the sash opening in this case.
Another note. If the window is certified through AAMA, and has a test report, part of the testing is forced entry resistance. The tecnician is given various tools that most people possess, and a given amount of time to break in.
Hope this helps.
Hope this helps.
