1 - 20 of 38 Posts
I am contractor, working on my own a home in an area far from where I
live.
Switching from baseboard to heat pump....Hvac guy wants to install a Coleman 4ton. (13 or 14 seer, not sure)
My question is, is this a decent unit? My hometown guy does American standard and swears by it. Is it like the chevy ford dodge thing?
He also said that Goodman and Coleman are the same, I can have either.
I have many more questions if any hvac guy wants to play along.
Thanks in advance.
Coleman - Good or Bad?
it ALL depends on the quality of the installation and the attention to details by the installer
Not a truer statement. You can bet it is a bad machine on a bad install. I took out a 23 year old coleman unit last year. We installed another brand, but the coleman had served it's purpose. Make sure your guy has done some great installs.
With the way things are made today, I wouldn't trust any of the machines to last 23 years.
Go for a 10 year parts and labor warranty and ride it out! Get it looked at every year and change your filters at least every month!
Good Luck with your new unit.
Carrier Heat Pump
Not worth starting a new thread... What about the quality of "Carrier" heat pumps? As I'm to have one installed soon.
Just make sure the install is correct. Duct, return air, power, proper airflow and correct settings of the out door thermostats and proper sizing of the auxiliary strips.
Around here, Carrier parts are much higher than others. Lennox, York and even Trane parts are more reasonable.
You get the name with Carrier..watch out for the Bryant/Day and Night/Payne shuffle. If you buy Carrier, get Carrier.
Get a 10 year Parts and Labor warranty. Have Fun!
Thats weird, here, they cost about the same as everybody else.
What's the difference between Carrier, Day/Night, and Payne? The parts are all the same, the cabinets look the same, and the warranties are equal. The only difference I can think of is that Carrier has dealership rights, and wont sell to the smaller outfits.
Come on, we know you can get an inducer motor for a Carrier for 366.00 and one for a Lennox for 144.00.. Goodman cheaper.
Carrier does charge more.
what's the difference... Communicating machines, lots of extra goodies, like hi and lo pressure switches, variable speed fans and multi speed condenser fans...
Maybe it is just Texas, Louisiana, Mississippi, and Alabama! :jester:
My hucklebuck self thought Tex was referring to a control board. The fancy stuff comes with some high dollars parts, brand A,B, orC. With most folks, I advise the basic 80 percent gear, and if they want to save a few bucks, go duel fuel. But, sometimes they want high efficiency, and there is no reason to tell them differently, unless they ask.
Dual Fuel...
With most folks, I advise the basic 80 percent gear, and if they want to save a few bucks, go duel fuel. .
:no:
Dual fuel uses a heat pump with auxiliary heat from a furnace.
I don't know about the north and northwest, but dual fuel in Texas is a joke. With LP or natural gas...
Natural gas is so cheap. Even with an 80% furnace, it is way cheaper than running a heat pump on a 50 degree day.
Love heat pumps, if they are installed correctly. Here in Texas, they have a 10-12 year life span.:sad:
How much is electricity per kh/hr down there? We pay eight cents during the winter and ten cents during the summer. Nat. gas is ninety seven cents a therm. Here it works out well because we have a lot of heat pump days. I would think that down there it would be the way to go as well. But, the cost electricity and gas are the big determinants.
Not a fan of condensing furnaces, perhaps they are great for those with the big fancy homes, or, a few other settings. They require more maintenance, and seem to "age"quicker than the standard 80%.
I really appreciate the old dinasores (spelling), I appreciate the lack of inducer fan, and those heat exchangers, man, almost never find a crack in them.
1 - 20 of 38 Posts
