Here is what you are looking for. Please call my friend Charles. I used to own an xiom and he may remember my name, Glen Isaacson. Either way he is a genius chemist and this is the best way to go. Good luck.
ITI SYSTEMS CORP.
2555 NE 11th ST, BOX 808
FORT LAUDERDALE, FLORIDA 33304
954-864-4949,
[email protected]
ItI systems corp. has developed a new line of extraordinary nano chemistry liquid inorganic coatings which require no oven cure, and are far superior to all existing powder coatings in almost every regard.
Features include:
1. Outstanding corrosion protection with salt spray tolerance up to 10,000 hrs.
2. Coatings form a flexible glass coating much like porcelain enamel on all surfaces.
3. Complete UV blocking to eliminate fading and UV degradation
4. Glass clear very smooth with no orange peel appearance. Can be tinted to give an anodized effect or used as a clear coat over any pigmented or non pigmented coating or substrate.
5. Superior bond on all surfaces including all metals, galvanizing, plastic, glass, concrete, and wood. Used under water on swimming pools and fountains.
6. Will not support the growth of mold, mildew, or bacteria
7. Completely anti graffiti. Inert in all petroleum products, acids, and solvents such as MEK, Acetone, Alcohol, gasoline, etc.
8. Non slip. Excellent for floors. Extremely wear resistant. Lasts up to five years in high traffic areas without renewal. Can be renewed without removal. Available in matte, semi gloss and high gloss.
9. We look forward to hearing from you.
10. Because no oven is required, size or location of substrate is no problem, inside or outdoors.
For further information please contact us at 516-398-0997 or e mail at
[email protected].
Charles R. Affatato
P.O. Box 1482
Port Washington, NY 11050
T: 516-398-0997
F: 516-883-6665
[email protected]
