1 - 4 of 4 Posts
Customer wants to replace old tub, acrylic tub and surround from the '70s. Alcove measures 58 1/2" end to end (drywall to drywall above surround) and 30 3/16" deep, tub is 60"(?) x 28". They want a 60"x30" new tub installed. My question is were tubs of this era a little shorter than the tubs of today. I can make the alcove a little deeper without a lot of problems but not looking forward to making it 1/2" wider to accommodate a new tub. Thanks for any info
Capra Aegagrus
Remodeler
Most likely you'll find 60" between the studs. A lot of the "drywall" from that era has a 1/2" base covered by a skim coat roughly 1/4" thick. You could verify that by drilling a couple of small holes to see how deep you go before hitting wood.
I agree with the above, the drywall might be going over a lip on the surround and you might be measuring where I assume there's corner bead?
Bathtub rough in lengths have been standardized for a looong time so unless this was a custom house with a custom built bathtub you should be fine. I've replaced tubs in houses built from the 40's on up and have never run into an opening that was less than 60".
1 - 4 of 4 Posts
