Nu heat can be wired in series,ther are some that have to hooked up in parallel like easy heat.
Check that i made a mistake,you cannot run any of these systems in series you cannot go over the rated requiremnts for the thermostat.So if you have multiple matts then you would need to get more thermostats to keep you under the amerage rating of that circuit.Sorry for the misinformation
