1 - 19 of 19 Posts
Everything that I have done and had inspected passed no problem. Did one for a code enforcement officer at his place 2 years ago and he had no objections.
notched in posts, but i have always been told it is not allowed... anyone know when this code took effect?
Told by whom?
Specifically, the only code pertaining to a handrail post is that it must withstand 200 lbs. of side pressure. Local building departments may have their own additional set of standards, though. I've got new requirements for handrail posts that are not specifically addressed in the IRC.
Having said that, notching your handrail post will significantly diminish it's strength. You also increase the chance for a a split to start at the notch.
Mac
Who has ever gotten a permit for building a deck? Do you really have to worry? I'm pretty sure you still get the required 200 lbs of strength with a notched railing, as I have seen them a lot. They have more play in them if you walk up to the railing and shake it, but who ever does that?
General Contractor
I've read a lot of rather surprising statements made by pros here, but I think you are now way ahead of whoever is in second place. Someone tell you these things were simply decorative?
Deck Designer/Builder
Are you on crack??? :rolleyes:
I built a deck at my house this summer without a permit.
That being said, you guys do know that in parts of the country permits aren't necessary, and if they are required. the BI doesn't look at it real close.:thumbsup:
General Contractor
Can anyone tell me why it seems to be that despite all the statements on this forum about "The Code" being no more than a guideline for the barest of minimums in sturdiness and safety, people who build without permits don't even seem to want to build their projects to that lowest of all standards?
Now, I can fully understand not wanting to line the city's pockets by buying a right to build on your own property. But that's not what I'm talking about. My puzzlement is over people just throwing good common sense construction methods and procedures out the window simply because no one is going to drive out and check their work.
We talk a lot about "hacks" here. To me, this is the epitome of being a hack.
Reactions: spdtrx
Fine Deckbuilder
Can't believe some of the statements.
Residential railing has to withstand a 200 lbs of pressure at any given point. They do tests at 2 1/2 times that rate (500 lbs)
Even a solid 4x4 bolted ( 2x 1/2") doesn't reach the rating. The problem is not the skirt / post connection, it is the connection between the skirting and the joist ( nailed into the end cut of the joist) There is not much force needed to pull this board out.
Simpson Deck Tension tie (DTT2Z) connection between the joist and skirt will pass this test. I joined a few weeks back a seminar of Simpson Ties (highly recommended) and they where not sure if this will be required yet in the 2009 IRC this fall. But we have a few counties (like Fairfax Virginia) that already do.
Notching a 4x4 halfway will reduce it strength by 70%.
If you like the look and you don't pull a permit or you think you don't have an inspection that that's up to you.
Never understood, why do more work (notching) to make it weaker.
Clemens
John Hyatt
YO Clem Mon, I bid a fence repair with the 4x4 corner posts daped in1 1/2'' on both sides of the 4x4, this relates to a 2x2,all the others were 1 1/2''.
This is the good part>> the ho wanted it that way said it looked Finished<< The JonMon showed Major restraint, but not on the Bid for replacement. FineHome Bulding had a frount cover deck that was done the same way on a 6x6 post holding up a two story deck a few years ago no lie! the post was daped out for a double 2x12 rim joists. Total Stupid and on the cover. J.
President of the world
Discussion Starter · #16 ·
Clemens
i thought the rim board had to be screwed with 3" screws?
anyway, my question is when, what year, did they say no notching.
also to mac: i heard it from other contractors, not a code book, so i am assuming they know what they are talking about... however i would take your expert advise, as this is your trade, over theirs.
and if that's the case... then my question is irrelivant
I eat sawdust.
Clemens
Sometimes I notch, most of the time I don't. It really depends on what the HO wants. I always use HTT16 tension ties. My suppliers still don't stock those new deck post ties, either.
Sean
Fairfax Virginia Deck Guide; Version: 2006.1, revised: 5/8/08
Prescriptive Residential Wood - Deck Construction Guide
Based on the 2006 International Residential Code
AKA --- DCA6 - 2008
No notching - screws through the rim board, etc...
1 - 19 of 19 Posts
