I recently had a new AC/Heating system installed with all-metal ducts (insulation on the exterior) and all-metal boxes. I went with all-metal to facilitate cleaning of the ducts. The system includes a 3-ton Carrier condenser, 3-ton Carrier air handler, Ultravation UV filter, Ultravation Hepa filter, 4 air returns, all covering 1650 sq.ft. under air.
The problem I am having is that in the cooling mode, the system produces an air noise through the ducts which is VERY LOUD. The technician said the noise is created by an uneven/turbulent flow of air exiting the air handler, and reccommended interior insulation of the plenum--the duct-work just outside of the air handler. Will this reduce the air noise? Are all-metal ducts always noisy? The sound produced is a bit like the noise in the interior of an airplane... Thanks in advance for your comments.
