1 - 20 of 92 Posts
Chief Reporter of Spam
I'm writing a contract Friday for a bath remodel with a tile floor. I had origionally talked about using ditra but lately a lot of you guys have been talking more about Noble TS and Noble Deck... I may want to give it a try and wondering the cost difference/quantity(sq ftg)...
I get a 54 sq ft roll of ditra for $75 bux so are the Noble products about the same or what??
Carpe Diem
NobleSeal TS is purchased by linear foot (it gets cut to order). It comes in 5' widths. So if you ordered quantity 1, you'd receive 5 sq ft (1' x 5').
Things to consider:
You use modified over and under it.
To seam 2 pieces together, you need a tube of NobleSealant 150.
It's much thinner than Ditra so keep that in consideration when determining floor height.
It's about .10¢ more per sq ft. However, you can use it on walls or floors (like Ditra + Kerdi in one). So buying in bulk can actually save you money in the long run.
Customer service is outstanding!
Discussion Starter #17
Ha! I heard you guys talkin about it and was just trying to get the facts straight... I do a lot of smaller bathrooms so I do like that I can get it in without seams, that's pretty cool :thumbup: + I like modified better
Discussion Starter #20
Angus, setting the Noble TS on plywood, is there a minimum thickness required? The guy at dal seemed to think 1".... I was thinking 3/4" is sufficient.
My price is $1.42 per sq. Ft. , is that reasonable? And they definately recomended the TS over the Dal version so I may give it a shot
1 - 20 of 92 Posts
