do you know the manufacturer? usually they have a detail
but ordinarily you just cut your R.O. then route the foam for 2x bucks
i would use a couple of beads of spray foam before i set the 2x
screw the 2x thru the sheathing on the outside and to the drywall on the inside
add the wrb, sliding it under the existing one on top
