Hello, CT
The furnace (Tempstar) 95% rate turns on and tests fine. I just can't get it to work with the thermostat. It does not turn off or on when set automatically. The two wires (R [RH, RC Jumpered] and W) are connected. Is the wire between the two messed up somewhere in the wall? Is the wiring wrong? Help!
Appreciate all the help I can get.
Thank you
Thank you
