New Flooring?
1973 Views 5 Replies 6 Participants Last post by  AustinDB
I have old wood flooring now with no plywood underneath. I want to install a new wood floor. I was wondering if I can just go over the top of the existing floor. There are no issues with height difference to other rooms or doors. Thanks for any help.
1 - 6 of 6 Posts
What do you mean there are no issues with height differences? There will have to be if you're laying wood on wood.
Well, at least you'll feel taller.
I think he's saying the entire house is hardwood, so theres no difference between each room.
To the poster - Thats extremely risky. You have to consider how many times the old hardwood has been sanded- how thick it is. Will it support the added weight of more hardwood and furniture, and people? Will the cleats or staples hold into split/damaged/thin/old wood? Wouldn't you save money on your heating bill by cutting out the old wood, and installing plywood. ---- Are you sure theres not slatboard under the hardwood you're missing?
Good luck.
EDIT: Use laminate if all else fails.
Alternative
Ditto about laying new wood over old wood. Technically I guess you can. In practice likely to have problems.
I'm going to disagree about the laminate. Yeah, you could, but we're assuming the floor is level, good quality of laminate, etc etc. Much better product is luxury vinly plank. I like Karndean, but there are several good brands. We would put down a layer of fiberock (1/4"), use Ardex on seams, screw heads or staples, etc., then do the lvp. Fantastic product, lots of colors, can even do an antique hand scraped look in extra heavy duty commercial grade. Most people think they are walking on hardwood.
It all depends.What kind of flooring is the old floor and what kind of flooring are you plannning to install.
If there is no plywood underneath you can have some lick and the old floor will start to lift the new floor.
It is allways safer to take off the old floor.
I think he is saying the flooring is the floor-no strip over ply like what is common of more recent homes. If that is correct, he may be asking if it's ok to install new 3/4" over existing 3/4" (or ~5/8" if it's been sanded) without doing any other prep. Can't remove the original flooring in a case like this-the walls are built atop of it.
1 - 6 of 6 Posts
