New construction stain/seal package advice
2099 Views 5 Replies 5 Participants Last post by  Dorman Painting
Ok guys, the title says it all. I've got a new construction stain/seal job coming up and I'm a little unsure about this job. I've done lots of new work projects but never stain packages. I did help a buddy years ago on one of his old stain jobs and it was a PITA.
I need some clever advice on how to go about this job. I was planning on spraying the stain and sealer before the trim guy puts it up...is this general procedure?? I guess I could let the trim guy put it up and then go behind him like we do on a normal prime/paint job but that seems more difficult.
I need tips please and I'm assuming I'll just use sanding sealer instead of poly...I know lots if guys that have good luck going that route.
1 - 6 of 6 Posts
Many years ago I helped a painter stain a lot of molding. He had a spray booth and did lots of spraying but for some reason opted for the following...
He had 2 new cotton wash mitts, wore rubber gloves under them, poured his stain into a clean 5 gallon bucket. It was my job to walk the molding away from him while he held the mitts, full of stain over the molding. As corny as it sounds, it worked great for the mass amount of molding he had to do. Of course the molding has to wiped after the stain sits a while.
Many ways to go about it, application wise. For even stain penetration, sand the trim with 220 grit sandpaper to remove the milling burnish, which can prevent the stain soaking in evenly.
Back in the day, we used to trim 95% stain it jobs, of apx 200/yr. As a trim carp, I hated pre sealed trim...stain, no problem. The sealer had a tendency to make the trim warp, dulled saw blades faster, & was near impossible to work with. Typically my jobs were stained, installed, sealed, color puttied, & finally top coated. All stain, & sealer was alykyd based, with poly top. The most popular was Porter products, with the sealer being "Twin Seal".
The most important part was for the trim carp to color match the work. It started with sorting. Then off color was used where it was least seen.
Oil based stains are way more forgiving to work with than water based....just brush on, let stand for maybe a minute, & then wipe down with fresh cotton rags.
Typically two guys could easily knock out a 3,000' home worth of stain in 1/2 day.
Joe
Be careful with the sanding sealer. Some polys don't work well with certain sanding sealers, read the labels before you proceed.
My buddy who's doneva bunch of these back in the 80's and early 90's, says to spray in one room and stack them in another room. He said it's a ton of work just handling the trim 3 or 4 times and of course sanding in between.
I'm going to try and tackle it but thhs job sounds like I need to charge 6-8k just to make a little money. The house is about 1500 square feet, so it's not overly huge.
1 - 6 of 6 Posts
