What's the question ?
Did he ask you for any advice or input ? If not a wise man would mind his own shop.
You're screwing the painter at that rate or he's to dumb to know any better. At that rate, the painter is probably only making about 95 cents a sq. foot after material, deduct labor and he's down to 70 cents, deduct insurance and gas, he's down to 60 cents etc.New construction painting is a whole different game.
Typical proceedure is - spray primer, and roll behind. spray all trim work, roll walls, done.
My painter for high end - sand everything, fill and patch as necessary, prime everything, sand again, minimum two coats on trim and walls.
New construction is all about being fast, they don't do anything not necessary. Up here it's going for about $ 1.25 and the painter supplies the paint.
My custom guy charges by the job not the square foot. Probably about 3 times the cost of new construction. But you are comparing a ford to a ferrari :whistling
Sorry, should have explained further. I don't do new construction. This is what the painter was getting on a subdivision where I was doing the warrany repairs.You're screwing the painter at that rate or he's to dumb to know any better. At that rate, the painter is probably only making about 95 cents a sq. foot after material, deduct labor and he's down to 70 cents, deduct insurance and gas, he's down to 60 cents etc.
For the work involved in new houses, especially the caulking, puddy, sanding etc, I'm sure glad I don't do new residential. Working for my friend has been a sharp reminder of the PITA and cheap labor expected from builders....oh and they expect perfection too.lmao.
Just did the math, that last job works out to $ 6.15/sq.ft. Only hacks would work for $ 1.25
Goes back to - learn a trade, develop skills, make some money :thumbup:
For sure. He is usually booked 4-6 months in advance. His work, as I have said is flawless. Never had a complaint.Sounds like your painter has a good gig
Im sure it is. Painting is a big PITA, thats why good painters make good money.For sure. He is usually booked 4-6 months in advance. His work, as I have said is flawless. Never had a complaint.
When the job calls for 'top drawer', there aren't many guys to call upon.
Don't want to ask the no,no, question, but do you think this is fair compensation for this level of work. I think it is.
