I am going to be doing a bath remodel and will need to run a new circut to the spa tub. The tub will need a dedicated 15 Amp circut, but I wanted to upgrade it to a dedicated 20Amp. The bath is located 60 feet from the panel and is on the same wall. I want to run metal conduit from the panel along the outside of the house and then penetrate the stucco and bring the condut to the interior. My question is the termination from the outside to inside. What is the proper install?
I was planning to use a conduit body at the end of the run before going into the wall. do I need to connect that to a J-box that is set into the exterior? then continue the conduit to my receptical?
How about weatherization? remember it is a Stucco exterior, and is there a code on how far from the ground I can run the conduit along the outside of the house? I was thinking for athetics I would run that aprox. 12" from ground.
