I will never use bondo again. Wanted to make nice boxes/ columns( for railing outside) less then a year later it's falling off. Had to scrape and redo what a pain. What else could I use? Any advice?
Yup, it's the same type of polyester resin material, and does not expand and contract the same as wood, and although sometimes it holds up indoors in some applications, I would not use it outdoors. Use a wood epoxy for outdoor wood instead.
If I understand you correctly, your wrapping a porch post to create an architectural column using trim board and your ending up with a lot of seam exposure- am I correct....:blink:
Try using FF biscuits and TB III , glue & clamp the column- good . You can sand the seam areas lightly after drying and the seam will not be visible if done correctly and will last as long as the wood is maintained with a repaint when needed . I am not a big fan of filling imperfections. Nail holes - understandably but major areas......
Jason Whipple is enamored with filling and restoring , he does nice work but I don't like the idea of fillers personally...
I always prefer to "design" seam issues out of a column........especially exterior.
V-beading.......etc.
I assume all exterior seams will eventually become visible due to material movement.
When I must fill, I rely on Abatron products. Been using their WoodEpox for a few years now, and it has never let me down.
