A framer at a construction site wants to connect to the Temp. power pole to run his 120-volt air-compresor and lights but can only find a L6-30R availble. What I understand is that a L6-30 is a 240 volt connection only and that it isn't legal to connect to only one hot leg and the ground for 120-volts, which we know will work on a house panel since the neutral and ground conductors are bonded in the panel.
Does anyone know if this is permissable, especially if it is wired into a NEMA 3R or NEMA 4 box with GFCI protection?
Thanks
Deadshort
Thanks
Deadshort
