Mudd Dogg said:
On the pressure washing aspect, do I need to use some sort of cleanser or will just straight water suffice?
Mudd Dogg,
You may want to consider using the following specifications:
Step #1: Thoroughly rinse all surfaces and surrounding areas with water prior to applying the biodegradable mildewcide treatment.
Step #2: Pre-wash surfaces by saturating with the mildewcide treatment and allow to stand. This will kill the mildew and loosen contaminates.
Step #3: Pressure clean surfaces to remove all chalk, dirt, mildew and insect nests, adjusting pressure as not to damage different substrates.
Setp #4: To complete the cleaning process, thoroughly rinse all surfaces and surrounding areas with water to remove all residue.
DRY-OUT: Allow 24 to 72 hours to dry-out before applying paint products.
Hope this helps.
Tom
RANGER Painting & Pressure Cleaning, Inc.
