Hi,
Appreciate you taking a look at this. I have not done any additions yet which require this. thus asking for advice. The house is on a slab so therefore putting addition on a slab. Can you just butt the 2 slabs against each other to pass code? I am in NC and understand you may not be. But looking for what you might do where you live. Also in the picture you see the red ridge board or whatever you might call it. We plan on using 16" I joists I know for a 12-14' span its overkill but hoping to get all the ductwork and electrical through it. Will be spacing them 16" on center. How would I go about attaching the ridge board to the house? Will it require posts from the ground up? Or is there a feasible way to attach it to the upstairs walls? Havent run into this before. IF you have any other questions please post and will try to answer them ASAP. They had other contractors tell them that they couldnt do vaulted ceilings in the addition. Trying hard to get them what they want. Hope picture helps sorry made it in MPaint.
Thanks Houston
Thanks Houston
