1 - 13 of 13 Posts
I need help. I have a deck that runs the length of the rear of my house.Half of the deck is under a sunroom addition. I want to replace the 2x6 deckboards on the deck side so I have to cut the 2x6's where they meet the sunroom.What would be the best way to flush cut the
2x6's?? Thanks
Love me some Concrete
Seriously????
Really???????
There is no way you are a contractor! They teach that exact cut on Day 3 of contractor school or did you fall alseep that day?
This space for lease
Are you ever sure flush cutting would be the best way to go? It might look like the best way for a while but the ends should be fastened. I'd cut on a supported area if possible, otherwise add a supported area under the short section left over.
General Contractor
Nothing beats to have the right tools for the job. Investing into this saw even just to do your job, will worth every penny ( you can rent it also :laughing:)
Good luck
Pictures would help.
I would hope that the walls are properly supported.
There is the possibility that the structure was a homeowner no plan job.
Be careful what you cut.
Skilsaw. Sawz all and a sharp chisel should get the job done.
1 - 13 of 13 Posts
