Production cabinet companies will most likely have their own profiles.
I doubt you will get an exact match.
Just go for close.
CarpenterSFO said:The little groover in my post, plus roundover will do it, or a beading bit like this: http://www.freudtools.com/p-105-triple-beading-bits.aspx plus the little groover to round the internal bead.
Hmm interesting. The thing is this guy who made it isn't a production cab company. It was made out of a small local shop. He called it a French bead. But I see what your saying.
So far haven't seen anything close. I wonder if it has to have two passes one on each side
Probably made on a moulder rather than router or shaper. I've got a woodmaster moulding machine & can have affordable custome knives made. He may have done the same.
2nd half of your post makes no sense to me.
That is an applied bead. Use the bit posted. They make all sorts of sizes, but it's probably 1/4" with a 1/16" shoulder.
Even the interior molding is applied.
Would it be easier with a molder? Sure. But you can easily get that with applied moldings.
