I just got a Trane XC95 communicating unit with a Nexia XL1050 thermostat. I want to connect my Aprilaire 700 humidifier. Since it's a communicating setup there's no way (that I know of) to connect the Aprilaire's humidistat because the terminals on the furnace control board are disabled in communicating mode. But there are connections for an external humidifier on the control board that supply 120V when the communicating thermostat (Nexia XL1050) calls for humidity. I was considering connecting these to the primary of a 120/24 transformer whose secondary is wired directly to the humidifier. That way, when the wires go hot the fan and water solenoids in the Aprilaire will be energized. Trane and Aprilaire offer little advice and the installer was unfamiliar with hooking up a humidifier with a communicating thermostat so I'm hoping someone here can tell me if this is the correct way or if there is another.
SaveShare
Reply Quote
SaveShare
Reply Quote
