1 - 20 of 30 Posts
I own stock in FotoMat!
Four years ago (December 2013), I noticed the battery in my war wagon was 8 years old. So I stopped at the local NAPA store and bought a replacement so I wouldn't have to worry about it for a few more years.
January 2015, it wouldn't hold a charge. I pulled it, and the ends were bulging out. So back to the store I go, battery and receipt in hand to get a warranty replacement.
December 2015, same thing. Won't hold a charge, and the ends were bulged out. I return it, but can't find my receipt. So I end up buying a third battery.
Yep, you guessed it. January 2017, it starts all over again. Even sitting overnight with the negative disconnected, it won't hold a charge. Pull it out, and the ends are bulging out. Again, back to the store I go, battery and receipt in hand to get a warranty replacement.
Now here we are starting out 2018. And............ the FOURTH BATTERY won't hold a charge. Yeah, it's damned cold out now, but it should at least turn on the friggin' LED dome light! You guessed it...... ends are bulging out like Oprah's love handles.
Now, swapping out the battery isn't a big deal. Pop the hood and in two minutes I've got it out with just a 5/16" socket. Drop it into my pickup bed and stop by for a replacement. Two minutes to reinstall. But dammit, it's a friggin' pain to have to drag out the engine starter just to go to work for the day. :censored:
Screw their warranty. Screw their batteries. Four strikes, they're OUT! NAPA = Not Another Pain in the Arse.
I only got a couple years out of my last Napa batteries and now my current ones have me worried. We rarely get very cold here but the last few morning have been in the 20's and it definitely didn't kick over like it usually does. I have 2 batteries so I have to change 2 at a time!
What are you going to change to?
Administrator
Sawdust follows Me Everywhere
That sure seems strange it is bulging out the ends. Dumb question, but it is not over charging is it.
Was thinking the same thing. Batteries bulge for a few reasons. Overcharging, to fast of a charge or to rapid of a discharge for to long of a period of time.
Especially if it keeps happening on the same vehicle. If you had this happen on different batteries in different vehicles then something would be out of sorts with the NAPA batteries.
I agree, something else is going on. Recheck voltage as it should be between 13.7-14.3 volts. Check it with everything off and vehicle at 2,000RPM. Check it with a full load at idle, and at a higher RPM.
"Most aftermarket car batteries sold in the United States are made by three companies that build them for retailers: Johnson Controls, which supplies more than half of the market, Exide, and East Penn."
https://www.consumerreports.org/cro/car-batteries/buying-guide
Read Only
yup
If I remember correctly Napa batteries are made by exide. I’ve never had an exide battery last any length of time. The best ones have been Johnson controls, followed by East Penn for long life.
Contractor of the Month
I'm pretty sure they have been DEKA for the past decade, which I think is made by East Penn.
Reactions: backhoe12
I just got a new battery for my van yesterday, did a little research and Walmart Maxx (made by JC I think) batteries came pretty highly recommended. The old battery was a NAPA. No bulges.
Remodel
The bulges happened when the battery froze. Weak cell or the battery didn't fully charge.
FWIW, some vehicles have an insulating sleeve around the battery to protect it from heat from the radiator or some other component. I've seen these get taken out and not put back in, so you go through batteries.
Administrator
FWIW, some vehicles have an insulating sleeve around the battery to protect it from heat from the radiator or dome other component. I've seen these get taken out and not put back in, so you go through batteries.
OK, then there's 4 ways.:thumbsup:
In my local NAPA store there are 2 kinds of batteries - red-stickered, cheap ones, and blue-stickered, more expensive ones. We go through a fair amount of batteries at the farm and have had pretty good luck with the blue-stickered ones. The red ones are crap, and we won't buy them.
I agree with the others up there though that if all this is happening in the same rig, it's probably not the batteries.
Sure, I can do that...
This last cold snap, my truck had been parked for a week over Christmas. Battery calfed and would barely pop the solenoid.
Pulled the battery into the house over night, reinstalled in the morning and it fired right up.
No bulge to the case, and the posts were a bit skanky with corrosion, so cleaned that mess up.
Napa battery from early 2012, so it has paid itself off already. Usually get 5 to 7 years on a truck battery out here.
Remodel
uncharged freezing batteries bulge also. i've had them split the case
I see that every winter, or almost every winter. I have about half a dozen used spares that if they lose too much of their charge, they freeze and bulge. Sometimes there is just one weak cell that freezes.
1 - 20 of 30 Posts
