I was thinking that seems unique.......to me.....Is it common practice to run the soffit / fascia before the trusses are set?
He must have a good truss guy,Is it common practice to run the soffit / fascia before the trusses are set?
No kidding. Then again it's probably a safe enough gamble on a double gable.jlsconstruction said:He must have a good truss guy,
I did a garage that had similar "built in loft" trusses. The verticals that formed the walls for the loft had a 3-1/2" variance in them planing out. Had the shrink the width of the loft and fur out the verticals with 2x8's.jlsconstruction said:He must have a good truss guy,
I would do that too, given the chance. You tell the truss guy you want 14 1/2" tails (for example) and they cut them at that, or you cut them off the stack yourself. Trust but verify. Not as easy as soffits with stick-built, but still better than doing OH off scaffolding. Walls are stiffer and straighter, too.Is it common practice to run the soffit / fascia before the trusses are set?
yes12" overhang?
No, I was too busy.Tavern or not today KH?:laughing:
