It took me about 10 years of constant tweaking, but I've finally achieved the perfect tool belt. (at least for me)
On both sides I have 5 pocket pouches. I can't stand having to fiddle around looking for things that have fallen to the bottom of a pocket.
On my left side pouch, I riveted in some small individual holders, one for my *****, one for my chisel, one for my ricky bar, another for both needle nose and screwdriver. I also have a piece of reinforced pvc tubing to hold my cat's paw in place. On the outside is a holder for my Stanley 199. (I'm very old school)
In front I attached a large tape holder with the keeper strap cut off. I carry a 30 footer and remove the belt clip. It's a perfect fit, easy to pull out but it won't fall out if I bend over.
On the right pouch I cut a small hole at the bottom of the top pocket so my speed square (I write with my left hand) will drop all the way down. I also added that rivet to keep it at exactly the right height. Also, after a while I figured out that a flat bar fits perfectly between the pouch and the belt in case I need to have that with me.
The very last mod I did is my favorite. On either side of my tape I attached a hook. I then attached a tiny bungee with a split ring to my impact and drill. That way I never have to set them down. It's especially handy when working on a ladder.
Yes, when fully loaded with all the tools and full of fasteners it weighs about as much as a two year old, so I use suspenders. I tried a couple different brands before I found those DeWalts. I've had to have a couple of the seams on the left pouch stitched back up a couple of times, but it's probably 20 years old. The right side used to be a 4 pocket until I was able to find a 5 pocket. It's probably 5 years old. I do have to replace the belt itself about once every year or two but that's no big deal.
If you can beat my setup, I'd love to see it.
