1 - 11 of 11 Posts
When you guys do a roof, do you always remove an old mushroom vent with a new one?
The one i am seeing is in perfectly good working order. I imagine we could properly flash it.
I'm "assuming" you are talking about a box or turtle vent. I've never heard them called a mushroom vent. Anyway, vents are pretty cheap comparatively speaking.... why not just replace it with a new one? If you are talking about a turbine vent which does sort of resemble a mushroom, while they're a little more expensive, with the moving parts, I'd say it's even more important to replace them.
Kinda like re-using your oil filter when you change your oil. It just doesn't make sense not to do it. But, maybe that's just me. :blink:
The Dude
Untangler of blue spaghetti
I think he's talking about a power vent, not a 750.
Highly-pathetically speaking you might be able to. The motor also might give out any time since it's probably been on there 20 years.
I think I pay $80 for them? Worth every penny and you can match it with the rest of the flashing you're replacing.
Power vent was my first thought too.
If so that is a must too replace. Not even a question.
Premium Member
power said:
When you guys do a roof, do you always remove an old mushroom vent with a new one? The one i am seeing is in perfectly good working order. I imagine we could properly flash it.
Attic fan? If so chunk it, deck it and install soffit and ridge vent.
1 - 11 of 11 Posts
