We have installed a Munchkin MC120 in a home we are building. It is supplying heat for the radiant heat system as well as heat for an indirect 80 gallon water heater (Superstor Ultra SSU-80). This is the first time I have used one of these systems and so far we are not impressed. The house has a large master bath with large jacuzzi tub and multi valve shower with body sprays. I expected this system to more than supply enough hot water without running out. Wrong. With the shower on and the tub filling the water will last about 10 minutes. Thats garbage for spending this kind of money.
My plumber and I changed some of the settings on the boiler and increased the tank water temp to 130F, it was 120F. But that has only helped by allowing the shower and tub to run 12-15 minutes. The tub does have a large flow (5gpm) but the reason for getting this system was do to the water demand this house was going to have. There are still two other tub/showers upstairs as well as the kitchen and fourth 1/2 bath downstairs.
After reading the manual and it's settings I am thinking the Munchkin is not firing as hot as it should or could. The tank calls for heat after a 7* drop in temp. When it calls for heat the boiler fires and supplies the coil with hot water. From my understanding that boiler should fire as hot as it can so the water tank can recover as quickly as possible. But that does not seem to be the case. I think we should be getting 180F out of the boilers output so it heats the tank quickly. But what we are getting is considerably less. The output temp of the boiler is only 16-17* warmer/hotter than the input temp. So this boiler can only increase the temp by 17*? No way. The hole idea is that it can, I thought, take the input and pump out the pre set temp, in this case 180. But it's not close. Is this $3k boiler seriously only able to increase the water temp by 17*?
From the Munckin website
The "controller utilizes an algorithm to fully adjust the firing rate while maintaining the desired output temperature." In this case the output temp is set at 180. Which again we are not getting.
Now I do like that this system is fully adjustable but I'm not impressed by the domestic hot water supply. I can adjust it to be very efficient or to supply more hot water but right now just getting it to supply as much as I thought it could is proving difficult.
My next test is going to be to increase the tank temp to 140 and then if that does not help much, lower the change in temp to firing. So instead of the tank loosing a full 7* until the boiler fires I will set it to, say 3*.
My plumber is good but he does not know everything about the Munckin and it's system. The biggest concern or question is why will it not put out 180* water when the tank calls for heat? I was thinking maybe it's set to be efficient and thats why it's not fully firing and putting out the 180. I can't seem to find any setting for efficiency for the domestic part of the system. The other thought is that it's sensing the outside temp and noticing it's not crazy cold so it's not firing the boiler to it's full potential. Am I wrong thinking the boiler can and should put out 180* for the domestic?
Anyway sorry for this long post but I am trying to get some answers. If anyone has experience with these things I would be very appreciative to hear your thoughts.
