I recently remodeled two bathrooms on the first floor of a condo. Plumbing access was below, just like most of the houses we work on. Is it pretty much assumed, that you will need access from below a shower, to reconnect the drain? What do you do for drain connection if things don't line up. We have not run into the situation much. With us, either there is access from below, or we put in a tile shower.
Working on estimates for customers on the 3rd floor and don't want to leave out the repair costs for the ceiling below, if dated dimensioning, or lack of budgeted options for tubs, dictate, a new tubs drain location?
Last stock shower pan I put in was 36x36 and center, was still center, are tub drain locations usually different, as I have noticed?
