1 - 6 of 6 Posts
Have a customer who wanted wall liner hung over top drywall. (there was wall paper and they did a piss poor job of removing it.)
I've never hung wall liner before so I did a little research, talked to a couple local guys and then hung it up. I let it dry then mudded the seams.
Half the seams held and the other half bubbled and the mud cracked. My customer has NOT seem this mess yet.
Should I seal the wall liner with primer then go back and mud it or lift the seams and glue it down first?
I do NOT want to tear down but if I have to lift every seam and glue it down I will. I just don't want to waste my time and make a bigger mess of it.
This customer has given me a lot of work and I want to make this right.
Any ideas?
wall liner
I would NEVER suggest to anyone to mud wall liner unless it was already sealed with at least one coat of paint that has cured.
I suppose there is a trick to it, but new wall liner is very moister sensitive, the seams can not be over lapped or butted right up against each other; they need to have a bit of a gap between them.
1 - 6 of 6 Posts
