So I'm finally starting to figure out how to work my sprayer a little bit, but I came up with two more dumb questions:
When I'm brushing trim, I can fill small gaps with paint. What do I do when I'm spraying? I tried spraying extra heavy, but that just made a mess. Do I have to caulk everything with a microscope? Touch up with a brush? How does that usually work?
Second, how do I spray trim that requires multiple passes from different angles? Window and door trim have to get sprayed from the side and from the front, right? I always get way too much paint on there when I do two passes.
